- Mute
- Permalink
- Report
Why the linear nest report is not showing for imperial duct element
Why the linear nest report is not showing for imperial duct element ? The Error is showing "There is nothing to print".
- Mute
- Permalink
- Report
automarza-
When are you getting this error? Is it after you selected the objects to be included in the nest report or when you are trying to print the report?
Nate
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
automirza-
Your reports being used, what is the directory of them. I've seen this issue in the past when migrating from older version to new when the newer products want a new folder for CAMduct, CADmep. For example if you reports are in a MIS directly then you should have a folder MIS/CAMduct, and one MIS/CADmep. Also there has been issue in the past which i haven't noticed but when mixing fields from different groups it sometimes wont work or if there is to many fields to print on the sheet you will also get this warning.
Nate
