- Mute
- Permalink
- Report
Issue with Pipe Size
I"m using a standard specifcation (ADSK IMPERIAL) to create some PVC Drain, Waste, and Vent Pipe. I know that schedule 40 pvc pipe at 3/4" diameter is an available product, but I can't seem to figure out how to change my settings to allow me to use this size pipe. The smallest size available is 1-1/4" diameter. How do I change the settings to allow the smaller pipe?
- Mute
- Permalink
- Report
Steve - The Service you are using is based off the Charlotte cataloge which starts at 1-1/4" (see image). If you are able to get 3/4" DWV PVC Sch40 from a different manufacurer you would need to build or have someone build the cataloge for the supplier needed.
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
- Mute
- Permalink
- Report
Thanks. I tried changing the service condition to 1/2" and it didn't do anything. Charlotte has 1/2" pipe available in schedule 40 pvc.
http://www.charlottepipe.com/Documents/Specs/Spec_PVC_40_Pressure.pdf
- Mute
- Permalink
- Report
Are you doing a Pressure system or Waste system? The Charlotte catalog for Pressure is available under Mechanical.
