davidronson
Project Navigator is a great solutiont to file management! I have used and implemented it in conjunction with Fabrication CADmep. Unfortunately, it is not in the vanilla CAD and AutoCAD MEP is not offered in the new Fabrications Suite.
The Navigator keeps your drafters in CAD as much as possible. The amount of time wasted pathing through Windows to open, view, or xref a file is amazing. Navigator lets you stay in program for these features, it also ties in the SheetSets function that is more widely used since it is in vanilla CAD.
**Caution** This is the only problem I have found with using it in conjunction with Fabrication. IF you have seperate databases for Pipework and Ductwork, DO NOT use the Xref Repair tool! Each file contains a cache of information from the database, the cache will get swapped out and corrupt all the fittings in model. It is not repairable and you will need to restore a back up. **Caution**
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
