davidronson
In CAD at the command line type "folders" This will bring up the known folder structure for the ITM library. If you want to include a new folder, right click on the parent folder and pick New Folder, enable "Add Sub Folders Too" then click Browes, path to the folder you want to include and click "ok".
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
