- Mute
- Permalink
- Report
2016/9/18:21:49:40 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:21:49:40 Resul RESULBEKCI Path_Length: 154
2016/9/18:21:49:40 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/18:21:49:40 Resul RESULBEKCI Launch
2016/9/18:21:49:40 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/18:21:49:40 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIC3F7.tmp
2016/9/18:21:53:16 Resul RESULBEKCI === Setup ended ===
2016/9/18:21:49:58 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:21:49:58 Resul RESULBEKCI Path_Length: 154
2016/9/18:21:49:58 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIC3F7.tmp
2016/9/18:21:49:58 Resul RESULBEKCI Launch
2016/9/18:21:51:28 Resul RESULBEKCI Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/18:21:51:28 Resul RESULBEKCI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/18:21:51:29 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/18:21:53:16 Resul RESULBEKCI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/18:21:53:16 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AIC3F7.tmp\Setup\AcSetup.dll
2016/9/18:21:53:16 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/18:21:53:16 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/18:21:53:48 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/18:21:53:48 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/18:21:53:48 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/18:21:53:56 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/18:21:53:57 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:21:54:01 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:21:54:01 Resul RESULBEKCI Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/18:21:54:07 Resul RESULBEKCI Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/18:21:54:07 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/18:22:19:45 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/18:22:19:45 Resul RESULBEKCI Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/18:22:20:02 Resul RESULBEKCI Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/18:22:20:02 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/18:22:20:28 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/18:22:20:29 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/18:22:21:19 Resul RESULBEKCI Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/18:22:21:20 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/18:22:22:12 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/9/18:22:22:13 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:23:08 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:23:08 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/18:22:23:24 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/9/18:22:23:24 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/18:22:23:30 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/18:22:24:39 Resul RESULBEKCI === Setup ended ===
2016/9/18:22:25:40 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:22:25:40 Resul RESULBEKCI Path_Length: 154
2016/9/18:22:25:40 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/18:22:25:40 Resul RESULBEKCI Launch
2016/9/18:22:25:40 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/18:22:25:40 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIB968.tmp
2016/9/18:22:25:50 Resul RESULBEKCI === Setup ended ===
2016/9/18:22:25:44 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:22:25:44 Resul RESULBEKCI Path_Length: 154
2016/9/18:22:25:44 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIB968.tmp
2016/9/18:22:25:44 Resul RESULBEKCI Launch
2016/9/18:22:25:47 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/18:22:25:47 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/18:22:25:47 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AIB968.tmp\Setup\AcSetup.dll
2016/9/18:22:25:47 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/18:22:25:48 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/18:22:26:18 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/18:22:26:18 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/18:22:26:18 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/18:22:26:26 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/18:22:26:27 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:22:26:28 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:22:26:28 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/18:22:26:28 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/18:22:27:02 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/18:22:27:03 Resul RESULBEKCI Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/18:22:27:03 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/18:22:27:37 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/9/18:22:27:38 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:28:33 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:28:33 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/18:22:28:53 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/9/18:22:28:53 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/18:22:28:57 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/18:22:29:14 Resul RESULBEKCI === Setup ended ===
2016/9/18:22:44:08 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:22:44:08 Resul RESULBEKCI Path_Length: 154
2016/9/18:22:44:08 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/18:22:44:08 Resul RESULBEKCI Launch
2016/9/18:22:44:08 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/18:22:44:08 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIA34D.tmp
2016/9/18:22:44:23 Resul RESULBEKCI === Setup ended ===
2016/9/18:22:44:12 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/18:22:44:12 Resul RESULBEKCI Path_Length: 154
2016/9/18:22:44:12 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIA34D.tmp
2016/9/18:22:44:12 Resul RESULBEKCI Launch
2016/9/18:22:44:14 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/18:22:44:14 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/18:22:44:15 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AIA34D.tmp\Setup\AcSetup.dll
2016/9/18:22:44:15 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/18:22:44:17 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/18:22:44:31 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/18:22:44:31 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/18:22:44:31 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/18:22:44:53 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/18:22:44:54 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:22:44:54 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/18:22:44:55 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/18:22:44:55 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/18:22:45:13 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/18:22:45:13 Resul RESULBEKCI Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/18:22:45:13 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/18:22:45:58 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/9/18:22:45:58 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:47:48 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/18:22:47:48 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/18:22:48:23 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/9/18:22:48:23 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/18:22:48:24 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/18:22:48:39 Resul RESULBEKCI === Setup ended ===
2016/9/19:20:36:55 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/19:20:36:55 Resul RESULBEKCI Path_Length: 154
2016/9/19:20:36:55 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/19:20:36:55 Resul RESULBEKCI Launch
2016/9/19:20:36:55 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-77434132 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/19:20:36:55 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI4A7.tmp
2016/9/19:20:37:03 Resul RESULBEKCI === Setup ended ===
2016/9/19:20:36:59 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/19:20:36:59 Resul RESULBEKCI Path_Length: 154
2016/9/19:20:36:59 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI4A7.tmp
2016/9/19:20:36:59 Resul RESULBEKCI Launch
2016/9/19:20:37:01 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/19:20:37:02 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/19:20:37:02 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI4A7.tmp\Setup\AcSetup.dll
2016/9/19:20:37:02 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/19:20:37:03 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/19:20:37:14 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/19:20:37:14 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/19:20:37:14 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/19:20:37:59 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/19:20:38:01 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/19:20:38:01 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/19:20:38:02 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/19:20:38:02 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/19:20:38:42 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/19:20:38:43 Resul RESULBEKCI Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/19:20:38:43 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/19:20:39:13 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/9/19:20:39:14 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/19:20:41:10 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/19:20:41:10 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/19:20:41:35 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/9/19:20:41:35 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/19:20:41:37 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/19:20:42:07 Resul RESULBEKCI === Setup ended ===
2016/9/30:19:15:57 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:19:15:57 Resul RESULBEKCI Path_Length: 154
2016/9/30:19:15:57 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/30:19:15:57 Resul RESULBEKCI Launch
2016/9/30:19:15:57 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/30:19:15:57 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AID902.tmp
2016/9/30:19:17:44 Resul RESULBEKCI === Setup ended ===
2016/9/30:19:16:03 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:19:16:03 Resul RESULBEKCI Path_Length: 154
2016/9/30:19:16:03 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AID902.tmp
2016/9/30:19:16:03 Resul RESULBEKCI Launch
2016/9/30:19:16:06 Resul RESULBEKCI Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:19:16:07 Resul RESULBEKCI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:19:16:07 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:19:17:31 Resul RESULBEKCI Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:19:17:31 Resul RESULBEKCI Error downloading. Please Install Now again from the Autodesk website. 2016/9/30:19:17:45 Resul RESULBEKCI === Setup ended ===
2016/9/30:19:18:20 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:19:18:20 Resul RESULBEKCI Path_Length: 154
2016/9/30:19:18:20 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/30:19:18:20 Resul RESULBEKCI Launch
2016/9/30:19:18:20 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/30:19:18:20 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI49C.tmp
2016/9/30:19:19:50 Resul RESULBEKCI === Setup ended ===
2016/9/30:19:18:22 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:19:18:22 Resul RESULBEKCI Path_Length: 154
2016/9/30:19:18:22 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI49C.tmp
2016/9/30:19:18:22 Resul RESULBEKCI Launch
2016/9/30:19:18:23 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:19:18:24 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:19:19:50 Resul RESULBEKCI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:19:19:50 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI49C.tmp\Setup\AcSetup.dll
2016/9/30:19:19:50 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/30:19:19:50 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/30:19:19:59 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/30:19:19:59 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/30:19:19:59 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/30:19:20:03 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/30:19:20:03 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:19:20:03 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:19:20:03 Resul RESULBEKCI Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:19:20:13 Resul RESULBEKCI Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:19:20:13 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/30:19:20:57 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/30:19:20:57 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:19:21:33 Resul RESULBEKCI Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:19:21:33 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/30:19:22:06 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/9/30:19:22:07 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/30:19:22:58 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/9/30:19:22:58 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/30:19:23:12 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/9/30:19:23:12 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/30:19:23:13 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/30:19:24:02 Resul RESULBEKCI === Setup ended ===
2016/9/30:20:06:03 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:20:06:03 Resul RESULBEKCI Path_Length: 154
2016/9/30:20:06:03 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/30:20:06:03 Resul RESULBEKCI Launch
2016/9/30:20:06:03 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/30:20:06:03 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIB56C.tmp
2016/9/30:20:07:55 Resul RESULBEKCI === Setup ended ===
2016/9/30:20:06:05 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:20:06:05 Resul RESULBEKCI Path_Length: 154
2016/9/30:20:06:05 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIB56C.tmp
2016/9/30:20:06:05 Resul RESULBEKCI Launch
2016/9/30:20:06:14 Resul RESULBEKCI Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:20:06:15 Resul RESULBEKCI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:20:06:18 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:20:07:42 Resul RESULBEKCI Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:20:07:42 Resul RESULBEKCI Error downloading. Please Install Now again from the Autodesk website. 2016/9/30:20:07:56 Resul RESULBEKCI === Setup ended ===
2016/9/30:20:19:42 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:20:19:42 Resul RESULBEKCI Path_Length: 154
2016/9/30:20:19:42 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/30:20:19:42 Resul RESULBEKCI Launch
2016/9/30:20:19:42 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/30:20:19:42 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI3679.tmp
2016/9/30:20:21:12 Resul RESULBEKCI === Setup ended ===
2016/9/30:20:19:43 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:20:19:43 Resul RESULBEKCI Path_Length: 154
2016/9/30:20:19:43 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI3679.tmp
2016/9/30:20:19:43 Resul RESULBEKCI Launch
2016/9/30:20:19:44 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:20:19:45 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:20:21:12 Resul RESULBEKCI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:20:21:12 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI3679.tmp\Setup\AcSetup.dll
2016/9/30:20:21:12 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/30:20:21:12 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/30:20:21:39 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/30:20:21:39 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/30:20:21:39 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/30:20:21:42 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/30:20:21:43 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:20:21:43 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:20:21:43 Resul RESULBEKCI Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:21:47 Resul RESULBEKCI Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:21:47 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/9/30:20:22:05 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/9/30:20:22:05 Resul RESULBEKCI Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:09 Resul RESULBEKCI Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:09 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/30:20:22:28 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/30:20:22:29 Resul RESULBEKCI Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:32 Resul RESULBEKCI Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:32 Resul RESULBEKCI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Resul\AppData\Local\Temp\vcredist_x86_2010.log
2016/9/30:20:22:41 Resul RESULBEKCI Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/9/30:20:22:41 Resul RESULBEKCI Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:45 Resul RESULBEKCI Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:22:45 Resul RESULBEKCI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Resul\AppData\Local\Temp\vcredist_x64_2010.log
2016/9/30:20:22:58 Resul RESULBEKCI Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/9/30:20:22:59 Resul RESULBEKCI Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:23:04 Resul RESULBEKCI Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:23:04 Resul RESULBEKCI Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Resul\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/9/30:20:23:09 Resul RESULBEKCI Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/9/30:20:23:10 Resul RESULBEKCI Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:23:15 Resul RESULBEKCI Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:20:23:15 Resul RESULBEKCI Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Resul\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/9/30:20:23:19 Resul RESULBEKCI Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/9/30:20:23:19 Resul RESULBEKCI Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:20:23:28 Resul RESULBEKCI Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:20:23:28 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/30:20:23:39 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/30:20:23:40 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:20:24:17 Resul RESULBEKCI Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:20:24:17 Resul RESULBEKCI Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/30:20:24:17 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/30:20:24:17 Resul RESULBEKCI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/9/30:20:24:17 Resul RESULBEKCI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/9/30:20:24:17 Resul RESULBEKCI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/30:20:24:17 Resul RESULBEKCI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/30:20:24:19 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/30:20:26:01 Resul RESULBEKCI === Setup ended ===
2016/9/30:21:04:14 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:21:04:14 Resul RESULBEKCI Path_Length: 154
2016/9/30:21:04:14 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/9/30:21:04:14 Resul RESULBEKCI Launch
2016/9/30:21:04:14 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/9/30:21:04:14 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIF9D6.tmp
2016/9/30:21:05:45 Resul RESULBEKCI === Setup ended ===
2016/9/30:21:04:18 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/9/30:21:04:18 Resul RESULBEKCI Path_Length: 154
2016/9/30:21:04:18 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIF9D6.tmp
2016/9/30:21:04:18 Resul RESULBEKCI Launch
2016/9/30:21:04:22 Resul RESULBEKCI Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:21:04:22 Resul RESULBEKCI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/9/30:21:04:22 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:21:05:45 Resul RESULBEKCI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/9/30:21:05:45 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AIF9D6.tmp\Setup\AcSetup.dll
2016/9/30:21:05:45 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/30:21:05:45 Resul RESULBEKCI PageOpen LaunchDialog
2016/9/30:21:06:02 Resul RESULBEKCI PageOpen LicenseDialog
2016/9/30:21:06:02 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/9/30:21:06:02 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/9/30:21:06:05 Resul RESULBEKCI PageOpen FullProgressDialog
2016/9/30:21:06:05 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:21:06:06 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/9/30:21:06:06 Resul RESULBEKCI Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:09 Resul RESULBEKCI Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:09 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/9/30:21:06:28 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/9/30:21:06:29 Resul RESULBEKCI Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:33 Resul RESULBEKCI Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:33 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/9/30:21:06:54 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/9/30:21:06:55 Resul RESULBEKCI Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:58 Resul RESULBEKCI Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:06:58 Resul RESULBEKCI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Resul\AppData\Local\Temp\vcredist_x86_2010.log
2016/9/30:21:07:07 Resul RESULBEKCI Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/9/30:21:07:07 Resul RESULBEKCI Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:11 Resul RESULBEKCI Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:12 Resul RESULBEKCI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Resul\AppData\Local\Temp\vcredist_x64_2010.log
2016/9/30:21:07:19 Resul RESULBEKCI Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/9/30:21:07:20 Resul RESULBEKCI Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:24 Resul RESULBEKCI Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:24 Resul RESULBEKCI Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Resul\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/9/30:21:07:29 Resul RESULBEKCI Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/9/30:21:07:30 Resul RESULBEKCI Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:35 Resul RESULBEKCI Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/9/30:21:07:35 Resul RESULBEKCI Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Resul\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/9/30:21:07:38 Resul RESULBEKCI Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/9/30:21:07:38 Resul RESULBEKCI Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:21:07:48 Resul RESULBEKCI Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/9/30:21:07:48 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/30:21:08:00 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/9/30:21:08:01 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:21:08:37 Resul RESULBEKCI Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/9/30:21:08:37 Resul RESULBEKCI Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/9/30:21:08:37 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/30:21:08:37 Resul RESULBEKCI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2016/9/30:21:08:38 Resul RESULBEKCI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2016/9/30:21:08:38 Resul RESULBEKCI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/30:21:08:38 Resul RESULBEKCI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/30:21:08:38 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/9/30:21:08:55 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:26:20 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:26:20 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:26:20 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/10/18:17:26:20 Resul RESULBEKCI Launch
2016/10/18:17:26:20 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/10/18:17:26:20 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI7EEE.tmp
2016/10/18:17:26:28 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:26:24 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:26:24 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:26:24 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI7EEE.tmp
2016/10/18:17:26:24 Resul RESULBEKCI Launch
2016/10/18:17:26:27 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/10/18:17:26:27 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/10/18:17:26:27 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI7EEE.tmp\Setup\AcSetup.dll
2016/10/18:17:26:27 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/10/18:17:26:27 Resul RESULBEKCI PageOpen LaunchDialog
2016/10/18:17:27:40 Resul RESULBEKCI PageOpen LicenseDialog
2016/10/18:17:27:40 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/10/18:17:27:40 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/10/18:17:27:54 Resul RESULBEKCI PageOpen FullProgressDialog
2016/10/18:17:27:56 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:27:57 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:27:58 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/10/18:17:27:58 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/10/18:17:28:54 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/10/18:17:28:56 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:17:29:33 Resul RESULBEKCI Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:17:29:33 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/18:17:30:10 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/10/18:17:30:10 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:30:59 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:30:59 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/10/18:17:31:24 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/10/18:17:31:24 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/10/18:17:31:28 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/10/18:17:33:17 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:34:00 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:34:00 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:34:00 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/10/18:17:34:00 Resul RESULBEKCI Launch
2016/10/18:17:34:00 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/10/18:17:34:00 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI843C.tmp
2016/10/18:17:34:07 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:34:01 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:34:01 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:34:01 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI843C.tmp
2016/10/18:17:34:01 Resul RESULBEKCI Launch
2016/10/18:17:34:06 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/10/18:17:34:06 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/10/18:17:34:06 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI843C.tmp\Setup\AcSetup.dll
2016/10/18:17:34:06 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/10/18:17:34:07 Resul RESULBEKCI PageOpen LaunchDialog
2016/10/18:17:34:16 Resul RESULBEKCI PageOpen LicenseDialog
2016/10/18:17:34:16 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/10/18:17:34:16 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/10/18:17:35:08 Resul RESULBEKCI PageOpen FullProgressDialog
2016/10/18:17:35:09 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:35:09 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:35:09 Resul RESULBEKCI Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:17:35:09 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/10/18:17:35:30 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/10/18:17:35:30 Resul RESULBEKCI Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:17:35:30 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/10/18:17:35:52 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/10/18:17:35:52 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/10/18:17:35:52 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/10/18:17:36:01 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/10/18:17:36:01 Resul RESULBEKCI Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:17:36:01 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/18:17:36:31 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/10/18:17:36:32 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:37:21 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:37:21 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/10/18:17:37:42 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/10/18:17:37:43 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/10/18:17:37:44 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/10/18:17:38:34 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:42:05 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:42:05 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:42:05 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/10/18:17:42:05 Resul RESULBEKCI Launch
2016/10/18:17:42:05 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/10/18:17:42:05 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIEC79.tmp
2016/10/18:17:42:13 Resul RESULBEKCI === Setup ended ===
2016/10/18:17:42:08 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:17:42:08 Resul RESULBEKCI Path_Length: 154
2016/10/18:17:42:08 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AIEC79.tmp
2016/10/18:17:42:08 Resul RESULBEKCI Launch
2016/10/18:17:42:09 Resul RESULBEKCI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/10/18:17:42:09 Resul RESULBEKCI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/10/18:17:42:10 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AIEC79.tmp\Setup\AcSetup.dll
2016/10/18:17:42:10 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/10/18:17:42:12 Resul RESULBEKCI PageOpen LaunchDialog
2016/10/18:17:42:44 Resul RESULBEKCI PageOpen LicenseDialog
2016/10/18:17:42:44 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/10/18:17:42:44 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/10/18:17:42:56 Resul RESULBEKCI PageOpen FullProgressDialog
2016/10/18:17:42:57 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:42:57 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:17:42:57 Resul RESULBEKCI Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:17:42:57 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/10/18:17:43:15 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/10/18:17:43:16 Resul RESULBEKCI Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:17:43:16 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/10/18:17:43:35 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/10/18:17:43:42 Resul RESULBEKCI Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/10/18:17:43:42 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/10/18:17:43:52 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/10/18:17:43:52 Resul RESULBEKCI Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:17:43:52 Resul RESULBEKCI Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/10/18:17:44:22 Resul RESULBEKCI Install Autodesk Material Library 2016 Succeeded
2016/10/18:17:44:24 Resul RESULBEKCI Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:45:15 Resul RESULBEKCI Download Aborted CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2016/10/18:17:45:15 Resul RESULBEKCI Install Autodesk Material Library 2016 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/10/18:17:45:39 Resul RESULBEKCI Rollback Autodesk Material Library 2016 Succeeded
2016/10/18:17:45:39 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/10/18:17:45:39 Resul RESULBEKCI PageOpen InstallCompleteDialog
2016/10/18:17:46:23 Resul RESULBEKCI === Setup ended ===
2016/10/18:18:12:26 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:18:12:26 Resul RESULBEKCI Path_Length: 154
2016/10/18:18:12:26 Resul RESULBEKCI Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2016/10/18:18:12:26 Resul RESULBEKCI Launch
2016/10/18:18:12:26 Resul RESULBEKCI CommandLine /PK 001H1 /SN 900-69129687 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2016/10/18:18:12:26 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI18ED.tmp
2016/10/18:18:14:07 Resul RESULBEKCI === Setup ended ===
2016/10/18:18:12:28 Resul RESULBEKCI === Setup started on RESULBEKCI by Resul ===
2016/10/18:18:12:28 Resul RESULBEKCI Path_Length: 154
2016/10/18:18:12:28 Resul RESULBEKCI Current Directory C:\Users\Resul\AppData\Local\Temp\_AI18ED.tmp
2016/10/18:18:12:28 Resul RESULBEKCI Launch
2016/10/18:18:12:34 Resul RESULBEKCI Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/10/18:18:12:35 Resul RESULBEKCI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2016/10/18:18:12:35 Resul RESULBEKCI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/10/18:18:14:07 Resul RESULBEKCI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2016/10/18:18:14:07 Resul RESULBEKCI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Resul\AppData\Local\Temp\_AI18ED.tmp\Setup\AcSetup.dll
2016/10/18:18:14:07 Resul RESULBEKCI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/10/18:18:14:07 Resul RESULBEKCI PageOpen LaunchDialog
2016/10/18:18:14:15 Resul RESULBEKCI PageOpen LicenseDialog
2016/10/18:18:14:15 Resul RESULBEKCI PageOpen ProductInfoDialog
2016/10/18:18:14:15 Resul RESULBEKCI PageOpen ProductSelectionDialog2
2016/10/18:18:14:26 Resul RESULBEKCI PageOpen FullProgressDialog
2016/10/18:18:14:27 Resul RESULBEKCI Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:18:14:27 Resul RESULBEKCI Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2016/10/18:18:14:27 Resul RESULBEKCI Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:18:14:31 Resul RESULBEKCI Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:18:14:31 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/10/18:18:14:51 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/10/18:18:14:55 Resul RESULBEKCI Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:18:14:59 Resul RESULBEKCI Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2016/10/18:18:14:59 Resul RESULBEKCI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/10/18:18:15:17 Resul RESULBEKCI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/10/18:18:15:18 Resul RESULBEKCI Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/10/18:18:15:27 Resul RESULBEKCI Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2016/10/18:18:15:27 Resul RESULBEKCI Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/10/18:18:15:38 Resul RESULBEKCI Install DirectX Runtime Succeeded
2016/10/18:18:15:39 Resul RESULBEKCI Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:18:16:20 Resul RESULBEKCI Download Aborted CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2016/10/18:18:16:20 Resul RESULBEKCI Install Autodesk Material Library 2016 Failed Download Failed, Installation aborted, Result=1603
2016/10/18:18:16:20 Resul RESULBEKCI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
