ezervas
in reply to: komondormrex
Hi, thanks and apologies for taking that long to respond.
Creating the string and pasting it in the command line works. It even works with a simpler setup using the "HANDENT" command. But as long as you place the same text in a script file and try to run it, it does not. If rather than "SELECT" you apply the same operation to another command e.g. "MOVE", it works from the script file as well, as expected. But "SELECT" seems an edgy exception.
