in reply to: Sergio.D.Suárez
Hi Sergio,
I have tried the code, Now the error message box is not coming but Angle constraints are not get creating.
The object collection function codes are fine (I have tried that code separately), I thing " CreateGeometryProxy(oAxis2, oproxyAxis2)" function is not working for "comp".
Previously I have used below function to select the components by using Pick command and the Angle constraint function worked fine
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
compOcc = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyOccurrenceFilter,
"Select a component")
' If nothing gets selected then we're done
If IsNothing(compOcc) Then Exit While
comps.Add(compOcc)
End While
But Angle constraint function not working for below "comp" function
Dim comps As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each comp As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences
oFilename = comp.Definition.Document.displayname
If InStr(oFilename, "VLV_MAN") "Create<> 0 Or InStr(oFilename, "VLV_HYD") <> 0 Then
comps.Add(comp)
End If
Next
Please give me your suggestion for this
Thanks & Regards,
Manoj Sampath
