AdamAG99T
in reply to: SandmanINV
The most straightforward way I can think of to do this would be to copy the entire sheet to another empty drawing file and then copy it back to the drawing you want it in. Once you do that just simply change the sheet size. Unfortunately inventor wont allow you to simply copy a sheet within a drawing so you need to use another drawing as a workaround.
