07-18-2019
07:38 AM
- Mute
- Permalink
- Report
07-18-2019
07:38 AM
try the following code, I think it could work, I have placed the instruction on error resume next in the last for-next in case errors are generated in this sector, should control this sector of code then, if the previous block works. regards
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument Dim oAsmCompDef As AssemblyComponentDefinition = oAsm.ComponentDefinition Dim oAxis1 As WorkAxis Dim oAxis2 As WorkAxis Dim oproxyAxis1 As WorkAxisProxy Dim oAConstraint As AngleConstraint Dim comps As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection For Each comp As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences oFilename = comp.Definition.Document.displayname If InStr(oFilename, "VLV_MAN") <> 0 Or InStr(oFilename, "VLV_HYD") <> 0 Then comps.Add(comp) End If Next ' If there are selected components we can do something For Each comp In comps On Error Resume Next oAxis1 = oAsmCompDef.WorkAxes.Item ("Y Axis") oAxis2 = comp.Definition.WorkAxes("Y Axis") comp.CreateGeometryProxy(oAxis2, oproxyAxis2) oAConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oproxyAxis2, oAxis1, 0, 78593) '78594 refers to the undirected angle constraint solution type. 78593 refers to 'directed (which is default), and 78595 is the referenced vector solution Next
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
