- Mute
- Permalink
- Report
I've developed an add-in which is almost ready for distribution to all users in our company (~20 users).
What is the best way to do this?
Create an installer and then manually install it everywhere?
And after that, when I make changes, what is the best way to update everything?
Thanks in advance for your ideas.
- Mute
- Permalink
- Report
Back in the day, it was possible (using Visual Studio) to "publish" an executable to a shared network location. You'll still see this on certain Windows applications; Google Chrome can do this (depending on where the installer originates).
I've built most of my installers using Innosetup - which is free and relatively simple to get going with; although I've never found an "update" mechanism that works aside from emailing my fellow users on the head and saying "there's an updated installer for {addinNameHere} available at {path}"
I would love to hear other's suggestions though.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
- Mute
- Permalink
- Report
We have created a .bat file that starts with windows and copies the dll files each time windows starts!
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
like this:
xcopy "P:\xx\yy.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\zz.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\zz.addin" "C:\ProgramData\Autodesk\Inventor 20##\Addins\" /y
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Your thanks are appreciated.
Sometimes we all forget to take a look at the easy way....
Arthur Knoors
- Mute
- Permalink
- Report
I Copy the Addin file local (you can use the script provided here) and let that file point to the dll which is on the server, so if i need to update the dll, i just can overwrite it, next time users start up, the new version is loaded.
please feel free to "kudos"
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
P:\xx\yy
P:\xx\yy
P = the server
xx\yy is the path
Arthur Knoors
- Mute
- Permalink
- Report
I was pointing to message 4 from @bradeneuropeArthur
