07-16-2019
09:21 AM
- Mute
- Permalink
- Report
07-16-2019
09:21 AM
HI Chandra,
I have attached the latest drawing for you to see. It may make more sense. I have also made some notes on the print explaining what the two rules (Rule20 (Works) & Rule20 (Works) Test) are doing.
Rule20 (Works) is the best of the two rules at the moment. Ideally I would like to be able to insert the parameter from the assembly in a way that it will update anytime I change the value of the ItemLetter in the assy.
The ultimate result I'm looking for is to have this view completely label the end of each part with the ItemLetter followed by a consecutive number, ex X1, X2, X3. . .
Thank you for your help,
Jenny
