- Mute
- Permalink
- Report
HI Chandra,
I was not able to get the code above to work for me. I got the following error,” The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))” However, with the help of a coworker I was able to get one of the other codes (Rule 20) in my file to work. The code (Rule 20) has been modified to this:
Dim doc = ThisApplication.ActiveDocument
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "select line")
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet = oDrawDoc.ActiveSheet
' Set a reference to the drawing curve segment.
' This assumes that a drwaing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment = entity
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint As Point2d = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
' Create a few leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y - 1.8))
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y - 1.8 ))
' Create an intent and add to the leader points collection.
' This is the geometry that the symbol will attach to.
Dim oGeometryIntent As GeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
'Dim oNote As String
' oNote = oDrawDoc.ActiveSheet.DrawingNotes.LeaderNotes.Item(1).FormattedText
' 'MessageBox.Show( oNote, "Title")
'Dim sText As String
Dim sText As String
'ItemLetters = Parameter("J19708 metal item A.iam.ItemLetter")
'sText = oNote
' sText =oDrawDoc.ActiveSheet.DrawingNotes.LeaderNotes.Item(1).FormattedText
'MessageBox.Show( sText, "Title")
'sText = "<Parameter Resolved='True' ComponentIdentifier='" & strFilename & "' Name='ItemLetter' Precision='2'>" & ItemLetters & "</Parameter>"
Dim oLeaderNote As LeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
' ' Insert a node.
' Dim oFirstNode As LeaderNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
' Dim oSecondNode As LeaderNode = oFirstNode.ChildNodes.Item(1)
' Call oFirstNode.InsertNode(oSecondNode, oTG.CreatePoint2d(oMidPoint.X + 5, oMidPoint.Y + 5))
'End Sub
'' Get the first symbol definition
'Dim oSketchSymDef As SketchedSymbolDefinition = oDrawDoc.SketchedSymbolDefinitions.Item("test leader")
'' Create the symbol with a leader
'Dim oSketchedSymbol As SketchedSymbol = oActiveSheet.SketchedSymbols.AddWithLeader(oSketchSymDef, oLeaderPoints)
The one quirk is that I have to have a dummy leader set off to the side so that the code can refer to it in order to pull our custom property “ItemLetter”. Here is the line of code:
If you open the leader box it looks like this:
(Snippet was deleted, please see attachment)
This has been our best work around for this but I keep thinking there has to be a better way to do this.
The assembly we are labeling has a user parameter, “ItemLetter” as well. I was able to manually create a leader that worked really well, it would update anytime the ItemLetter was changed but I don’t know how to create the code for this. The manually created leader dialog box looks like this:
Is there a way to change this line of code so that it will insert the User Parameter from the assembly?
That would be ideal. Then I need to figure out how to do the following two things:
- Have this automated, as in automatically pick the parts and place the leaders. Right now I have to run it and then pick a part. We are trying to fully automate this print so the engineers can focus on larger, more complex projects.
- I need to figure out the code so that the ItemLetter is followed by a number that increases by one with each new part. Ex QQ1, QQ2, QQ3 and so on.
Thanks for the help!
