- Mute
- Permalink
- Report
iLogic - External Rule not found?
I have created some rules and they were working fine, but now it is staying that it cannot find certain external rules, even though they are in the exact place, is this normal for external rules? I am new to external rules, and wonder if its a behaviour of using them ?
- Mute
- Permalink
- Report
Fixed it, I have an iLogic folder in which I have further sub folders. This was causing the issue as I had only set up iLogic configuration to look for the top folder, adding the sub folder separately to this solved the issue.
- Mute
- Permalink
- Report
This could probably be logged as an idea: "Allow iLogic External Rules to look in subfolders" and would be a simple checkbox on the dialogue you showed above.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
- Mute
- Permalink
- Report
It seems to be limitation of Inventor. Please log a wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
