@hkempeneers,
Try below iLogic code.
Dim comp As ComponentOccurrence
comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Selecteer een component")
If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
    Prop = iProperties.Value(comp.NativeObject.Name, "Project", "Description")
Else
    Prop = iProperties.Value(comp.Name, "Project", "Description")
End If
Dim oAssDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities,"Selecteer een vlak")
'		make sure it Is a planar face
If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
		Dim oFaceProxy As FaceProxy
		comp.CreateGeometryProxy(oFace, oFaceProxy)
		oPlanarSurface = oFace.Geometry
		'add a sketch
		oSketch = oAssDef.Sketches.Add(oFaceProxy)
		'trying to choose an appropriate point
		'assume this planar face has one edge loop only
		oEdgeLoop = oFaceProxy.EdgeLoops(1)
		oMinPt = oEdgeLoop.RangeBox.MinPoint
		oMaxPt = oEdgeLoop.RangeBox.MaxPoint
		CenterPt = ThisApplication.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
		'get one point on the face and transform to the point2d on the sketch
		'oTextPt = oSketch.ModelToSketchSpace(oPlanarSurface.RootPoint)
		oTextPt = oSketch.ModelToSketchSpace(CenterPt)
		'add the textbox
		oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, "<StyleOverride FontSize='30'>" & Prop & "</StyleOverride>")
Else
		MsgBox( "Selecteer een vlak, en geen ronding, aub!")
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
