moeman69
308 Views, 2 Replies
Old Cbliss grease fitting ipart error on straight style fitting
First off I'm not to familiar with iparts so I'm looking for some help on how to fix this.
I believe the issue is with the work planes not being used on the straight style grease fittings.
There is no issue with all the angle style fittings that use const plane, nipple set plane, and work axis 1.
I've been trying to dig into this but seems my knowledge on how to fix it is not very strong.
Sergio.D.Suárez
in reply to: moeman69
Hello, edit the angle control sketch and redefine it with respect to the sketch 5. Not with the projected spherical geometry. Then I redefined the planes with problems. Now it seems to work.
I hope it will be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
moeman69
in reply to: Sergio.D.Suárez
Thankyou! Thanks for the explanation as well.
