- Mute
- Permalink
- Report
Dim comp As Object
Dim oAssDoc As Object
comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Selecteer een component")
oAssDoc = comp
If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
Prop = iProperties.Value(oAssDoc.NativeObject.Name, "Project", "Description")
Else
Prop = iProperties.Value(oAssDoc.Name, "Project", "Description")
End If
Dim oAssDef As AssemblyComponentDefinition = oAssDoc.Definition
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities,"Selecteer een vlak")
' make sure it Is a planar face
If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
oPlanarSurface = oFace.Geometry
'add a sketch
oSketch = oAssDef.Sketches.Add(oFace)
'trying to choose an appropriate point
'assume this planar face has one edge loop only
oEdgeLoop = oFace.EdgeLoops(1)
oMinPt = oEdgeLoop.RangeBox.MinPoint
oMaxPt = oEdgeLoop.RangeBox.MaxPoint
CenterPt = oAssDef.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
'get one point on the face and transform to the point2d on the sketch
'oTextPt = oSketch.ModelToSketchSpace(oPlanarSurface.RootPoint)
oTextPt = oSketch.ModelToSketchSpace(CenterPt)
'add the textbox
oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, "<StyleOverride FontSize='30'>" & Prop & "</StyleOverride>")
Else
MsgBox( "Selecteer een vlak, en geen ronding, aub!")
End If
