bradeneuropeArthur
 Public Sub PackAndGoSample(a As String)
        'SET THE APPLICATION TO 64 BIT
        Dim fio As System.IO.FileInfo
        Dim dirio As System.IO.DirectoryInfo
        fio = New System.IO.FileInfo(a)
        dirio = New System.IO.DirectoryInfo(fio.Directory.FullName)
        Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent
        Dim oPacknGo As PackAndGoLib.PackAndGo
        Try
            MkDir("C:\Temp\PackAndGo")
        Catch ex As Exception
        End Try
        oPacknGo = oPacknGoComp.CreatePackAndGo(a, "C:\Temp\PackAndGo")
        ' Set the design project. This defaults to the current active project.
        oPacknGo.ProjectFile = "C:\Vault\XYZ.ipj"
        Dim sRefFiles = New String() {}
        Dim sMissFiles = New Object
        Dim sRefcingFiles = New String() {}
        ' Set the options
        oPacknGo.SkipLibraries = True
        oPacknGo.SkipStyles = True
        oPacknGo.SkipTemplates = True
        oPacknGo.CollectWorkgroups = False
        oPacknGo.KeepFolderHierarchy = True
        oPacknGo.IncludeLinkedFiles = True
        ' Get the referenced files
        oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles)
        oPacknGo.SearchForReferencingFiles(sRefFiles, sRefcingFiles, False, dirio.Parent.FullName & "\_Dwg")
        ' Add the referenced files for package
        'oPacknGo.AddFilesToPackage(sRefFiles)
        'oPacknGo.AddFilesToPackage(sRefcingFiles)
        Dim xa = New String(sRefFiles.Length + sRefcingFiles.Length - 1) {}
        sRefFiles.CopyTo(xa, 0)
        sRefcingFiles.CopyTo(xa, sRefFiles.Length)
        'oPacknGo.AddFilesToPackage(sMissFiles)
        ' Start the pack and go to create the
        oPacknGo.AddFilesToPackage(xa)
        'MsgBox(xa.Length)
        oPacknGo.CreatePackage(True)
    End Sub
Arthur Knoors
Autodesk Affiliations:
