301 Views, 3 Replies
iLogic, save .idw sheet as PDF
Hi
We have this small code running in Inventor which auto saves a PDF copy of all .idw files when we save them.
But something is wrong and it comes with an Error message
“Argument ”Length” has to be equal or lager then 0”
Code looks like this
WorkspacePath = ThisDoc.WorkspacePath()
WorkspacePathLength = Len(WorkspacePath)
PathOnly = ThisDoc.Path
DirectoryPath = Strings.Right(PathOnly, PathOnly.Length-WorkspacePathLength)
PDFPath = "\\sbs 2011\files\Z\Tegninger PDF"
If(Not System.IO.Directory.Exists(PDFPath)) Then
    System.IO.Directory.CreateDirectory(PDFPath)
End If
ThisDoc.Document.SaveAs(PDFPath & "\" & ThisDoc.FileName(False) & ".pdf" , True)
