Hi!
Hi!!
The code is running well at some point, except these two points:
An error arises and i think it's because of:
1- I use a LOD iLogic
2- I have library and content center parts
The questions are:
A) how can i avoid the error message?
(I tried the " on error resume", but it's incompatible with the "try" statement).
(Also tried the "if the part is modificable= true then", but i think this will not work for this case).
B) The code will work for a LOD other than Master?
Regards
CCarreiras
