felix.cortes5K3Y2
2054 Views, 4 Replies
iLogic to Create Rectangular Pattern Of Part Feature
Hi Forum,
I am trying to write a code to create the a rectangular feature pattern and was wondering if someone could help me out. Here's what I have right now:
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oRectDef As RectangularPatternFeatureDefinition = oCompDef.Features.RectangularPatternFeatures.CreateDefinition("TOP", "X-Axis", _
														True, 2, 10)
Dim oPartFeature As PartFeature = oCompDef.Features.RectangularPatternFeatures.AddByDefinition(oRectDef)
Best regards,
Felix
Hi @felix.cortes5K3Y2 .
Attached is an example part file ( saved in Inventor 2017 ) for you to look at.
I just adapted the code/file found at this link for this example.
https://forums.autodesk.com/t5/inventor-customization/rectangular-pattern-part-ilogic/m-p/7599859#M7...
Below is the code found in the file in cases it helps future searches.
I hope this helps.
Curtis
'try to delete previous pattern, just for testing
Try
ThisApplication.ActiveDocument.ComponentDefinition.Features("TestPattern").delete
Catch
End Try
Dim oPD As PartDocument
oPD = ThisApplication.ActiveDocument
Dim oPCD As PartComponentDefinition
oPCD = oPD.ComponentDefinition
Dim oSWP As WorkPlane
oSWP = oPCD.WorkPlanes.Item(4)
Dim oBjCol As ObjectCollection
oBjCol = ThisApplication.TransientObjects.CreateObjectCollection
Call oBjCol.Add(oSWP)
Dim oSL3D As SketchLine3D
oSL3D = oPCD.Sketches3D.Item(1).SketchLines3D.Item(1)
Dim qtypattern As Integer
qtypattern = InputBox("How many to Pattern?", "Quantity of Pattern")
Dim oPath As Object
oPath = oPCD.Features.CreatePath(oSL3D)
Dim oRecFeat As RectangularPatternFeature
DistPrompt1 = InputBox("Input Distance of Pattern in cm?", "Distance of Pattern")
oRecFeat = oPCD.Features.RectangularPatternFeatures.Add(oBjCol, oPath, True, qtypattern, DistPrompt1, PatternSpacingTypeEnum.kDefault)
'rename pattern
oRecFeat.Name = "TestPattern"
Thanks for the link! It doesn't work for my application but I think the code provided below is pretty darn close to being able to create it. I tried classifying the sweep that exists on my part as a object collection but it doesn't seem to work on the last line of code.
Dim oPartComp As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oSweep As SweepFeature = oPartComp.Features.SweepFeatures.Item(2)
Dim oBjCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Call oBjCol.Add(oSweep)
Dim oAxis As WorkAxis = oPartComp.WorkAxes.Item(1)
oRectFeat = oPartComp.Features.RectangularPatternFeatures.Add(oBjCol, oAxis, True, 3, 10, PatternSpacingTypeEnum.kDefault)
Best regards,
Felix Cortes
Hi, try this code. I think you can put the name of the operation instead of the item number, try it and then tell us. I hope the code is useful for you. regards
Dim oPD As PartDocument = ThisDoc.Document
Dim oPCD As PartComponentDefinition = oPD.ComponentDefinition
Dim Xaxis As Object = oPCD.WorkAxes.Item(1)' Select X Axis
Dim oTop As PartFeature = oPCD.Features.Item(1) ' Select Feature form item number
	Call oBjCol.Add(oTop)
oRecFeat = oPCD.Features.RectangularPatternFeatures.Add(oBjCol,Xaxis,True, 5, 1, kDefault, , , , , , , , kAdjustToModelCompute, kAdjustToDirection1)
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks a ton Sergio! Works great
