garrettfulghum
Could you instead force the PDF creation when you save the part or assembly?
What Im assuming is happening is that the user updates the part, exports it to dxf, and just forgets to re-update the idw and export it?
If so you could have it when the user saves it as a dxf it will update the idw and then re-export it as a pdf. However if the changes are more than just a simple parameter change, some dims will require the user to fix them.
Comparing the two automatically is possible but I would imagine very difficult. BlueBeam pdf viewer allows you to overlay pdfs/images etc but the user still has to go in and check for changes.
