05-30-2019
12:02 PM
- Mute
- Permalink
- Report
05-30-2019
12:02 PM
Okay I feel your pain here,
Many times when I find myself needing to change the visibility of the same parts in my assembly I just stick all the parts in a browser folder and change the folders visibility manually. (It does it like a group)
However, if in your case you want to use Ilogic and the part names are all the same, the best way to loop it in my eyes is to use the:
'foreach occurrence in oAsmDoc.ComponentDefinition.Occurrences'.
Then to check to see if the occurrence.name is the part you want to change the visibility.
You might even want to consider creating LOD's to support that many parts to speed up Inventor if thats an option you can do. Let me know if this helps!
