- Mute
- Permalink
- Report
Hello all....
I hope somebody can help me on this.
I have directed my Default VBA project to where my .ivb is through Tools/App Options/File tab and Default VBA project.
Now, when i tried to set my shortcut through, Customize User Commands/Keyboard/Macros category - it is empty and couldn't find any of my macros!...
I have it working before...and with other computers, but i got this issue with one computer...so, What did i missed?
Regards..
JR
- Mute
- Permalink
- Report
What is the file-size of your .ivb file, you are loading?
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Should it matter....? Its 1243 kb only.
What i don't understand is that the macro is working in the other computer, however with the other two computers, it is not. It is just because i couldn't just see the macro.
Perhaps, the program that reads vba is corrupted?
- Mute
- Permalink
- Report
You could try to repair it:
Close Inventor and install from your source
64-bit: \3rdParty\x64\VBA\Vba7.MSI.
32-bit: \3rdParty\x86\VBA\Vba7.MSI.
Could you post the file? Maybe it's corrupt.
There is a similar case:
- Mute
- Permalink
- Report
If the VBA project file was really empty than the size should be small.
I only wanted to check if there are modules in the VBA project file.
Arthur Knoors
- Mute
- Permalink
- Report
The .ivb file is fine...it actually works in my computer...but when i tried it to another computer, I was able to direct the file path to the .ivb file but when i tried to assign a shortcut key to the macro (in the customize toolbar) it doesn't show in there...it's just blank.
- Mute
- Permalink
- Report
the .ivb file is working fine in other computer, it is just specific to the other 2 computers...I might just have to re-install it somehow if all else doesn't work, it is just I wanted to know what is causing this and fix this without re-installing everything.
- Mute
- Permalink
- Report
Can you find any macro under the macro button in the ribbon of inventor?
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
What happens if you pres ALT + F11 within inventor, is it opening VBA editor?
Arthur Knoors
- Mute
- Permalink
- Report
actually, Alt+F11 opened the VBA editor and i found out there was nothing on it..
I overwrite it with the working .ivb on another computer and it all fixed the problem...so Thanks a lot for your time...
