sellvakumarmech
in reply to: dgreatice
it's working great, but I can't reduce the column width less the length of text(Column titel). when I use column width as 0.1. its returns as text length column width. could you please find a solution to this issue.
oCustomTable.Columns.Item(1).Width = .1
is there any possibility to kill the problem ASAP.
thanks in advance
Selvakumar v
Tags (1)
