bradeneuropeArthur
Maybe you try to edit a Library file with the Vault project file.
Since this is not possible you receive this error!
Opening and editing library files needs to be done with a separate project file.
Is this the case for you too?
Arthur Knoors
Autodesk Affiliations:
