- Mute
- Permalink
- Report
Convert Text parameter to Numeric parameter
Dear All,
At this moment im facing a problem I can't seem to solve. I have a master file with a form to setup all parameters for the parts/assemblys linked. Numeric parameters can be exported, but text parameters can't. So im looking for a way to convert them.
In my forms I have several options to choose, for example the type of brace mounting.
1 welded with a square plate
2 welded with a rounded plate
3 Bolted plate
4 No bracing
I wan't to choose in my form one of the options above. Then im looking for a solution to convert for example ''Welded with a square plate'' to the numeric value of 1. ''No bracing'' get the numeric value of 4.
So I can export the value to an assembly where the parts get changed/suppresed based on rules.
Is there a workaround for this problem?
Many thanks
