Inventor - Vault Add-in has a prompt options (Vault Ribbon\File Status section \ Vault Options \ .Check In dialog, Settings...  \ Visualizationg Attachment Options \ Do no create.  You can set a prompt option to do that (done so in the past), but if you're not careful you may default yourself out of the options you want.
jvj
