blindholm16
392 Views, 1 Reply
Place part views on active sheet
Attempting to use this iLogic below to select a part and then place two views on the active sheet, not seeing why the views are not getting generated. Any help appreciated.
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc As DrawingDocument
Dim oPartDoc As PartDocument
Dim oSheet As Sheet
Dim oIsoView As DrawingView
Dim oFlatView As DrawingView
ViewScaleFlat = 1 / 4
ViewScaleIso = 1/14
'Present a File Selection dialog
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
oPartDoc = oFileDlg.FileName
End If
' Current open drawing sheet
oDrawingDoc = ThisApplication.ActiveDocument
oSheet = oDrawingDoc.ActiveSheet
' Create a new NameValueMap object
Dim oBaseViewOptions As NameValueMap
oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
'False = flat pattern view
oBaseViewOptions.Add("SheetMetalFoldedModel", False)
'Bottom left corner points for views
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(7, 7.125) ' iso view
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(20, 18)' flat pattern
'Place the Views
oIsoView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, ViewScaleIso, kIsoTopRightViewOrientation, kHiddenLineRemovedDrawingViewStyle)
oFlatView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint2, ViewScaleFlat, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oBaseViewOptions)
BL
