04-30-2019
01:52 PM
- Mute
- Permalink
- Report
04-30-2019
01:52 PM
Hi, this ilogic rule is an example. Look on sheet 1, the first view, and look for the model of the view and if it is assembly, it will return a dialogue box with assembly, and if it is part it will return a message box with part.
This if you have the drawing file open
Dim oDoc As DrawingDocument = ThisDoc.Document Dim oView As DrawingView oView = oDoc.Sheets(1).DrawingViews.Item(1) oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then MessageBox.Show("Assembly") If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("Part")
If you want to see if the view in assembly or part in a file that is not open you could use something like this.
Dim oFileDlg As Inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw" oFileDlg.InitialDirectory = ThisDoc.Path oFileDlg.CancelError = True On Error Resume Next oFileDlg.ShowOpen() If Err.Number <> 0 Then MessageBox.Show("File not chosen.", "Dialog Cancellation") ElseIf oFileDlg.FileName <> "" Then selectedfile = oFileDlg.FileName MessageBox.Show("File " & selectedfile & " was selected.", "Dialog Selection Made") End If Dim oDoc As DrawingDocument = ThisApplication.Documents.Open(selectedfile, False) Dim oView As DrawingView oView = oDoc.Sheets(1).DrawingViews.Item(1) oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then MessageBox.Show("Assembly") If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("Part") oDoc.Close
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
