Darkforce_the_ilogic_guy
375 Views, 4 Replies
find out if it is a Part Drawing og assambly Drawing using Ilogic
is it possible to make a liogic code , se if the model that are use in the drawing is a part(.ipt) or an assambly(.iam) ?
and how do i do it
Tags (2)
I think you are looking for this code. I briefly tested it and it seems to work.
ThisDoc.Document.ReferencedDocuments(1).DocumentType
12290 is a Part
12291 is an Assembly
Hi, this ilogic rule is an example. Look on sheet 1, the first view, and look for the model of the view and if it is assembly, it will return a dialogue box with assembly, and if it is part it will return a message box with part.
This if you have the drawing file open
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oView As DrawingView
oView = oDoc.Sheets(1).DrawingViews.Item(1)
oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then MessageBox.Show("Assembly")
If oModelDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("Part")
If you want to see if the view in assembly or part in a file that is not open you could use something like this.
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
MessageBox.Show("File not chosen.", "Dialog Cancellation")
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
MessageBox.Show("File " & selectedfile & " was selected.", "Dialog Selection Made")
End If
Dim oDoc As DrawingDocument = ThisApplication.Documents.Open(selectedfile, False)
oDoc.Close
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
thanks for your answer that was just what I needed. think that just save me more then an hour of saving times on a large drawing, that I was not getting anything form
Tags (1)
thanks for the answer. I did end up using the other code. but it always nice to get some new input in how  you might do it
Tags (1)
