nicolamora
476 Views, 2 Replies
VBA code to unflag "USE THICKNESS FROM RULE"
I need a VBA code to unflag the "Use Thickness from Rule" in the sheet metal style property.
I tried the "ThisDoc.Document.ComponentDefinition.UseSheetMetalStyleThickness = False" but give me a debug error.
Also the following code:
Sub ChangeUseThicknessFromRule()
  Dim doc As PartDocument
  Set doc = ThisApplication.ActiveDocument
  Dim cd As SheetMetalComponentDefinition
  Set cd = doc.ComponentDefinition
  cd.UseSheetMetalStyleThickness = False
End Sub
 Not sure where is the error.
Nicola
