04-18-2019
07:55 AM
- Mute
- Permalink
- Report
04-18-2019
07:55 AM
I do not have the variables of your drawing file, so I can not test the rule in depth. But I want to ask you something ... Are you using the external rule in a new file? keep in mind that the line
oThisFileName = ThisDoc.FileName (False) & Extentie
it refers to the file in which the rule is made (which is supposed to be a drawing file, but in the if - then rules it specifies that it can be an ipt or a iam). If the file is not saved the filename will be "" nothing. I suppose that for this place the error should be, the access to the project file seems to be fine.
regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
