Charlies_3D_T
775 Views, 5 Replies
Ilogic working local but not in external rules
The rule below works perfectly when i run it in a drawing. But when i place it in external rules and run it nothing happens. Someon an idea?
Imports System.IO
Imports System.Collections
Imports System
Dim
IPJ As String Dim IPJ_Name As String Dim IPJ_Path As String Dim FNamePos As Long 'set a reference to the FileLocations object. IPJ = ThisApplication.FileLocations.FileLocationsFile 'get the location of the last backslash seperator FNamePos = InStrRev(IPJ, "\", -1) 'get the project file name with the file extension IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos) 'get the project name (without extension) IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4) 'get the path of the folder containing the project file IPJ_Folder_Location = Left(IPJ, Len(IPJ) - Len(IPJ_Name)) oThisDoc = ThisDoc.Document If TYPE_PLAN = "Detailtekening" Then Extentie = ".ipt" Else If TYPE_PLAN = "Lassamenstelling" Or TYPE_PLAN = "Ssamenstelling" Then Extentie = ".iam" End If 'Full name of the to search .ipt or .ass' oThisFileName = ThisDoc.FileName(False) & Extentie Dim Folder As New IO.DirectoryInfo(IPJ_Folder_Location) Dim FileList As New List(Of String) For Each File As IO.FileInfo In Folder.GetFiles(oThisFileName,IO.SearchOption.AllDirectories) If File.FullName.Contains(oThisFileName) = True Then FileList.Add(File.FullName) NieuwFilePath = File.FullName doc = ThisDoc.Document 'Change the Referenced File' oFD = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference(NieuwFilePath) Else MsgBox("the file " & oThisFileName & " not found in this project!") End If Next iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate()
The problem is located that i can't get the custom propertie Type_Plan. Because when it's an external rule it doesn't read the prop. Someon knows how i can read that property?
Think that you need to pass the active document to the external rule, Like:
Public Sub Main ()
External_Rule(ThisApplication. ActiveDocument)
End Sub
Public Sub External_Rule (Doc as Document)
End sub
Arthur Knoors
Autodesk Affiliations:
I do not have the variables of your drawing file, so I can not test the rule in depth. But I want to ask you something ... Are you using the external rule in a new file? keep in mind that the line
oThisFileName = ThisDoc.FileName (False) & Extentie
it refers to the file in which the rule is made (which is supposed to be a drawing file, but in the if - then rules it specifies that it can be an ipt or a iam). If the file is not saved the filename will be "" nothing. I suppose that for this place the error should be, the access to the project file seems to be fine.
regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
@Sergio.D.Suárez @bradeneuropeArthur
No the property Type_Plan is in all my drawings. But the strange thing is that it doesn't read it. So i need to know how to read it.
Normaly you can use this:
'define the property set
customPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
'---------------- find or create custom properties -------------
'look for the custom propety and add it if not found
oTest = customPropertySet.Item("TYPE_PLAN")
Try to define the string as described in its example, as an external rule it worked for me.
Dim IPJ As String
customPropertySet = oThisDoc.PropertySets.Item("Inventor User Defined Properties")
oTYPE_PLAN  = customPropertySet.Item("TYPE_PLAN").value
If oTYPE_PLAN = "Detailtekening" Then
Extentie = ".ipt"
'MessageBox.Show(Extentie)
Else If oTYPE_PLAN = "Lassamenstelling" Or oTYPE_PLAN = "Ssamenstelling" Then
Extentie = ".iam"
End If
		 	Else
            End If
Next
Mechanical Designer
@Sergio.D.Suárez
Now it's working thank you!
