04-08-2019
03:20 AM
- Mute
- Permalink
- Report
04-08-2019
03:20 AM
At the moment I can't test it on 2019; however please let me just make a note about two things on your code:
- As you are forcing the extension, it only works for .ipt references (if for some reason this drawing is for an iam, it will not work)
- Is the .idw read only? Don't know if you are using Autodesk Vault, but specially in that case, it may need a checkout
Later on, I will check it on 2019.
Hope it helps.
