If you dont want ilogicRules to run in other documents by triggers you could maybe do something like this at the top of your code
If oRulesEnabled = False
iLogicVb.Automation.RulesOnEventsEnabled = False
Else
iLogicVb.Automation.RulesOnEventsEnabled = True
End If
Where oRulesEnabled is a True/False parameter. So if it's set to false ilogic rules will not run.
