rhasell
in reply to: llorden4
Hi
I might have fix.
  • Open your template, I used the Test.idw you published.
  • Expand the Drawing resources, Title Blocks.
  • Right click, and Copy the Title block
Create a new Blank Drawing, Not using the title block (I think the problem is in the drawing file, not the title block)
So use one of the default templates if needed. (\Users\Public\Documents\Autodesk\Inventor 2019\Templates\)
  • Right Click on the Drawing Resources
  • Select Paste
Do the same for the Border, Copy and paste.
Cleanup and If needed delete any other unwanted items
Forgot to add, Transfer and custom properties
Save as a new template.
Fixed.
Reg
2025.2
