RoyWickrama_RWEI
1126 Views, 4 Replies
To Create Material Library for Material, Finish (Color) & Appearance
I am creating a comprehensive material library for material, finish (color and paint spec) and texture (expanded metal, perforated sheet, gratings etc.).
I tried with so many leads through the whole day. But could not get through a workable solution.
I shall be most grateful if someone help me.
Libraries to do with are:
Material libraries
  • Inventor Material Library
  • Autodesk Material Library
  • InventorMaterialLibrary_RWEI
Appearance Libraries
  1. InventorMaterialLibrary_RWEI
  2. RWEI Appearance Library
  3. RWEI Texture Library
  4. RWEI Appearance Library RAL
Sub Main()
	Dim oDoc = ThisDoc.Document
	Dim assetLib As AssetLibrary
	Dim oList_Assets As New ArrayList
	For Each oAssetLibrary In ThisApplication.AssetLibraries
	oList_Assets.Add(oAssetLibrary.DisplayName)
	Next oAssetLibrary
	oAssetLibrary_Selected = InputListBox("SELECT REQ'D LIB. FROM ABOVE!", oList_Assets, oList_Assets.Item(0), "CHANGE MATERIAL ASSET LIB.", "LIST OF ASSET LIBRARIES")
	oIndex = oList_Assets.indexof(oAssetLibrary_Selected)
'	Dim oAppearanceAssets As AssetsEnumerator
'	oAppearanceAssets = oPartDoc.AppearanceAssets
	oAssetlib = ThisApplication.AssetLibraries.oList_Assets(oIndex)
'	ThisApplication.ActiveAppearanceLibrary = oAssetLibrary_Selected.indexof(oAssetLibrary_Selected)
End Sub
Autodesk Inventor Professional 2019
Vault Professional 2019
