JhoelForshav
in reply to: tdant
You seem to have edited your answear to something completley different now...
That won't work for me as I want to be able to pick sub assemblies from different higher level sub assemblies...
I ended up doing a workaround where i build a Listbox containing the names of all selectable sub assemblies. Once an item in this listbox is selected i add the occurrenceproxy of that sub assembly to a highlightset to show the user which component will be selected. Then the selection is confirmed by klicking an OK-button.
