Jason.Rugg
468 Views, 8 Replies
See code below, anyone know why I am not getting B&W output???
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.ActiveDocument
' Set reference to drawing print manager' DrawingPrintManager has more options than PrintManager' as it's specific to drawing document
Dim oDrgPrintMgr As DrawingPrintManager
oDrgPrintMgr = oDrgDoc.PrintManager
pdfname = ThisDoc.FileName(False)
filePath = ThisDoc.Path
' Set the printer name' comment this line to use default printer or assign another one
oDrgPrintMgr.Printer = "Microsoft Print to PDF"
'Set the paper size , scale and orientation
oDrgPrintMgr.ScaleMode = kCustomScale
oDrgPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
'oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeLedger
oDrgPrintMgr.PaperSize = kPaperSizeTabloid
'oDrgPrintMgr.PaperSize = 14338
oDrgPrintMgr.PrintRange = 14082 'kPrintAllSheets
oDrgPrintMgr.Orientation = kLandscapeOrientation
'oDrgPrintMgr.PaperSource = 2
oDrgPrintMgr.AllColorsAsBlack = True
Dim doc = ThisDoc.Document
doc.SaveAs(filePath + "\" + pdfname + ".pdf", True)
'oDrgPrintMgr.SubmitPrint
@Jason.Rugg ,
Try this iLogic code.
Public Sub main
        ' Get the PDF translator Add-In.
        Dim PDFAddIn As TranslatorAddIn
        PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
        'Set a reference to the active document (the document to be published).
        Dim oDocument As Document
        oDocument = ThisApplication.ActiveDocument
        Dim oContext As TranslationContext
        oContext = ThisApplication.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        ' Create a NameValueMap object
        Dim oOptions As NameValueMap
        oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        ' Create a DataMedium object
        Dim oDataMedium As DataMedium
        oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
        ' Check whether the translator has 'SaveCopyAs' options
        If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
            ' Options for drawings...
            oOptions.Value("All_Color_AS_Black") = 1
            'oOptions.Value("Remove_Line_Weights") = 0
            'oOptions.Value("Vector_Resolution") = 400
            'oOptions.Value("Sheet_Range") = kPrintAllSheets
            'oOptions.Value("Custom_Begin_Sheet") = 2
            'oOptions.Value("Custom_End_Sheet") = 4
        End If
        'Set the destination file name
        oDataMedium.FileName = "c:\temp\test.pdf"
        'Publish document.
        PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
@chandra.shekar.g Thanks for the reply but the code you supplied also outputs in color instead of b&w.
@Jason.Rugg,
To illustrate black and white pdf export through previous iLogic code, a screencast video is prepared and uploaded to below link.
https://autode.sk/2CFiEHF
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
@chandra.shekar.g This does not work on my system, I have copied the above code as is and I can switch "All Colors As Black" back and forth from 1 to 0 and all prints come out in color.
Sorry this is not a solution.
@Jason.Rugg,
Can you please demonstrate the scenario with video record using non confidential data?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
@chandra.shekar.g There's really nothing to demonstrate, I took your code above and printed, it only outputs in color.
@Jason.Rugg,
Could you please provide non confidential drawing data to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
You can use any of the sample projects that come default with Inventor and a default template. These still output in color, so I know it has nothing to do with our data.
