Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As DrawingView
Set d = c.DrawingViews.Item(1)
Dim f As DrawingViewLabel
Set f = d.Label
Dim oColor As Color
'Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Red
Set oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0) 'Black
f.Color = oColor
b.Update
'dim co as
End Sub
Arthur Knoors
Autodesk Affiliations:
