machiel.veldkamp
198 Views, 1 Reply
Trying to make al text in viewlabels black.
Sub AllBlack()
	Dim LayerCollection As LayersEnumerator = ThisDoc.Document.StylesManager.Layers
	Dim Layer As Layer
	'Loop through LayerCollection
	For Each Layer In LayerCollection
		Dim aColor As Color = Layer.Color
		aColor.Red = 0
		aColor.Green = 0
		aColor.Blue = 0
		Layer.Color = aColor
	Next
	Dim oTextBoxes As TextBoxes
	Dim oDrawingNotes As DrawingNotes
	Dim oViewLabels As DrawingViews
	Dim oStyle As TextStyle
	oDoc = ThisDoc.Document
	Dim sht As Sheet
	For Each sht In oDoc.Sheets
		Dim note As DrawingNote
		Dim oView As DrawingView
		Dim oLabel As DrawingViewLabel
		For Each oView In sht.DrawingViews
			'MessageBox.Show("This is a Label", "Title")
			Dim oColor As Color = oViewLabels.Color
			oColor.Red = 0
			oColor.Green = 0
			oColor.Blue = 0
			Try
				oView.Label.Color = oColor
			Catch
			End Try
		Next
		For Each note In sht.DrawingNotes
			Try
				note.formattedText = note.Replace(note.formattedText, "<StyleOverride Color = '0,0,0'>" & note.formattedText & "</StyleOverride>")
			Catch
			End Try
			Dim oColor As Color = note.Color
			oColor.Red = 0
			oColor.Green = 0
			oColor.Blue = 0
			Try
				note.Color = oColor
			Catch
			End Try
		Next
	Next
	'oTextBox.FormattedText = "<StyleOverride Color = '0,0,0'>" & "</StyleOverride>"
End Sub
I'm trying to loop through all text on the drawing and I'm having some trouble making the text in the drawingview labels black.,
Anyone that sees where I'm wrong?
Thanks :slightly_smiling_face:
___________________________
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As DrawingView
Set d = c.DrawingViews.Item(1)
Dim f As DrawingViewLabel
Set f = d.Label
Dim oColor As Color
'Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Red
Set oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0) 'Black
f.Color = oColor
b.Update
'dim co as
End Sub
Arthur Knoors
Autodesk Affiliations:
