AlexFielder
in reply to: chrisdrogers
Fair enough; can you share a drawing with the same geometry that is failing as in your example? (Autodesk will ask for it anyway when they see/reply to this post)
Also, have you seen this example:
https://github.com/ADN-DevTech/Inventor-Training-Material/blob/master/Module%2015%20-%20Drawing%20Ad...
public void CreateBalloon()
             // Set a reference to the drawing document.
             // This assumes a drawing document is active.
              DrawingDocument oDrawDoc = (DrawingDocument)_InvApplication.ActiveDocument;
             // Set a reference to the active sheet.
             Sheet oActiveSheet  = oDrawDoc.ActiveSheet;
             // Set a reference to the drawing curve segment.
             // This assumes that a drwaing curve is selected.
             DrawingCurveSegment oDrawingCurveSegment   = oDrawDoc.SelectSet[1];
             // Set a reference to the drawing curve.
             DrawingCurve oDrawingCurve = oDrawingCurveSegment.Parent;
             // Get the mid point of the selected curve
             // assuming that the selection curve is linear
             Point2d oMidPoint  = oDrawingCurve.MidPoint;
             // Set a reference to the TransientGeometry object.
             TransientGeometry oTG  = _InvApplication.TransientGeometry;
             ObjectCollection oLeaderPoints  = _InvApplication.TransientObjects.CreateObjectCollection();
             // Create a couple of leader points.
             oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10));
             oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5));
             // Add the GeometryIntent to the leader points collection.
             // This is the geometry that the balloon will attach to.
             GeometryIntent oGeometryIntent  = oActiveSheet.CreateGeometryIntent(oDrawingCurve);
             oLeaderPoints.Add(oGeometryIntent);
             // Set a reference to the parent drawing view of the selected curve
             DrawingView oDrawingView   = oDrawingCurve.Parent;
             // Set a reference to the referenced model document
             Document oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument;
             // Check if a partslist or a balloon has already been created for this model
             bool IsDrawingBOMDefined = false;
             IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName);
             Balloon oBalloon = null;
             if (IsDrawingBOMDefined) {
              // Just create the balloon with the leader points
              // All other arguments can be ignored
              oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints);
             } else {
              // First check if the 'structured' BOM view has been enabled in the model
              // Set a reference to the model's BOM object
                 AssemblyDocument oAssDoc = (AssemblyDocument)oModelDoc;
                 AssemblyComponentDefinition oComDef = oAssDoc.ComponentDefinition;
              BOM oBOM =  oComDef.BOM;
              if (oBOM.StructuredViewEnabled) {
               // Level needs to be specified
               // Numbering options have already been defined
               // Get the Level ('All levels' or 'First level only')
               // from the model BOM view - must use the same here
               PartsListLevelEnum Level = default(PartsListLevelEnum);
               if (oBOM.StructuredViewFirstLevelOnly) {
                Level = PartsListLevelEnum.kStructured;
               } else {
                Level = PartsListLevelEnum.kStructuredAllLevels;
               // Create the balloon by specifying just the level
               oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints,null , Level);
              } else {
               // Level and numbering options must be specified
               // The corresponding model BOM view will automatically be enabled
               NameValueMap oNumberingScheme  = _InvApplication.TransientObjects.CreateNameValueMap();
               // Add the option for a comma delimiter
               oNumberingScheme.Add("Delimiter", ",");
               // Create the balloon by specifying the level and numbering scheme
               oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints,null , PartsListLevelEnum.kStructuredAllLevels, oNumberingScheme);
(I assume this ^ is similar to the API Example? - I haven't checked it yet)
:slightly_smiling_face:
