03-18-2019
12:05 AM
- Mute
- Permalink
- Report
03-18-2019
12:05 AM
@Anonymous ,
Try below iLogic code to select the material from the list.
Sub Main()
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oList As ArrayList = New ArrayList()
Dim oMaterial As Asset
For Each oMaterial In ThisApplication.AssetLibraries.Item(2).AppearanceAssets
oList.Add(oMaterial.DisplayName)
Next
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartCompDef As PartComponentDefinition
oPartCompDef = oDoc.ComponentDefinition
Dim oParams As Parameters
oParams=oPartCompDef.Parameters
Dim oUserParams As UserParameters
oUserParams=oParams.UserParameters
Dim oAwesomeParameter As Parameter
Try
otester = oUserParams.Item("material")
Catch
oInsulationType=oUserParams.AddByValue("material", oList.Item(1), kTextUnits)
End Try
End If
Parameter.Param("material").ExposedAsProperty = False
Parameter.Param("material").IsKey = True
MultiValue.List("material") = oList
selected_mat = InputListBox("Choose Part material", MultiValue.List("material"),oList.Item(1), Title := "Part material", ListName := "Available Standard materials")
Dim oAsset As Asset
oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item(selected_mat)
Dim oDocAsset As Asset
Try
oDocAsset = oDoc.AppearanceAssets.Item(selected_mat)
Catch
oAsset.CopyTo(oDoc)
End Try
Dim oCompDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oFaces As Faces
oFaces = oCompDef.SurfaceBodies(1).Faces
Dim AttSets As AttributeSets
Dim AttSet As AttributeSet
Dim oFace As Face
For Each oface In oFaces
AttSets = oface.AttributeSets
If AttSets.NameIsUsed("iLogicEntityNameSet") Then
AttSet = AttSets.Item("iLogicEntityNameSet")
For Each Att In AttSet
If Att.value = "Top" Then
oFace.Appearance = oDocAsset
End If
Next
End If
Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
