chandra.shekar.g
@Anonymous,
Try below iLogic code to change appearance of named face (In this code, "Top" is considered as named face).
Sub Main()
	Dim oDoc As PartDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oAsset As Asset
	oAsset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item("Cardboard")
	Dim oDocAsset As Asset
	Try
		oDocAsset = oDoc.AppearanceAssets.Item("Cardboard")
	Catch
		oAsset.CopyTo(oDoc)
	End Try
	Dim oCompDef As ComponentDefinition
	oCompDef = oDoc.ComponentDefinition
	Dim oFaces As Faces
	oFaces = oCompDef.SurfaceBodies(1).Faces
	Dim AttSets As AttributeSets
	Dim AttSet As AttributeSet
	Dim oFace As Face
	For Each oface In oFaces
		 AttSets = oface.AttributeSets
		 If AttSets.NameIsUsed("iLogicEntityNameSet") Then
		  	AttSet = AttSets.Item("iLogicEntityNameSet")
			  For Each Att In AttSet
			    If Att.value = "Top" Then
					oFace.Appearance = oDocAsset
				End If
			  Next
		 End If
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
