03-09-2019
03:33 AM
- Mute
- Permalink
- Report
03-09-2019
03:33 AM
Hi @RoyWickrama_RWEI , after a while I think I have found another method for what you were looking for, and it seems quite simple, it is one of your rules to which I have added a small function
Function FindParent(Parent As Document) As String 'Find real parent Line1 : Dim oBOMStructnumber As String oBOMStructnumber = Parent.ComponentDefinition.BOMStructure If oBOMStructnumber = 51971 Then Dim parent2 As Document = Parent.ReferencingDocuments.Item(1) Parent=parent2 GoTo Line1 End If Dim ParentName As String = Parent.DisplayName Return ParentName End Function
with a loop that returns the value of the real father, the one that is not phantom For each occurrence of the list of materials, I hope you understand and be useful to you, greetings.
Final Rule
Public Class RWEI_0007BOM Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main 'on error resume next Dim oAssy_ThisDoc As AssemblyDocument Dim oDoc As Document = ThisApplication.ActiveDocument Dim iL_NO As String = "0002-BOM" oDelete_ex_Notepad(oTextSave, iL_NO) Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: " oHL1 = HL1_Prefix & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) Dim iL_Name As String = "All Occurrences with BOM Structure" Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name oWrite_HeaderLines(oTextSave, oHL2) Dim oDashes As String = "" For i = 1 To Len(oHL2) oDashes = oDashes & "-" Next i Dim oHL3 As String = oDashes oWrite_HeaderLines(oTextSave, oHL3) Dim oHL4 As String = "" oWrite_HeaderLines(oTextSave, oHL4) Dim oBOM As BOM oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item(1)'Accesing to Model data Column Call ListItems(oBOMView.BOMRows, 0) Process.Start("Notepad.exe", oTextSave) End Sub Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer) Dim oBOMRow As BOMRow For Each oBOMRow In Rows Dim oBOMStructnumber As String oBOMStructnumber = oBOMRow.BOMStructure Dim BOM_Structure As String If oBOMStructnumber = 51969 Then BOM_Structure = "The Default Structure Type" If oBOMStructnumber = 51974 Then BOM_Structure = "The inseparable Structure Type" If oBOMStructnumber = 51970 Then BOM_Structure = "The normal Structure Type" If oBOMStructnumber = 51971 Then BOM_Structure = "The phantom Structure Type" If oBOMStructnumber = 51973 Then BOM_Structure = "The purchased Structure Type" If oBOMStructnumber = 51972 Then BOM_Structure = "reference Structure Type" If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references" Dim oDef As ComponentDefinition oDef = oBOMRow.ComponentDefinitions(1) Dim oFFN_X As String oFFN_X = oDef.Document.Displayname Dim oDocFile As Document oDocFile = oDef.Document Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1) 'First parent, check that is not phantom Dim RealParent As String = FindParent(Parent) 'Real parent is not phantom If Not oBOMRow.ChildRows Is Nothing Then Call ListItems(oBOMRow.ChildRows, indent + 1) End If oName_Parent = RealParent & "@" & BOM_Structure & "@" & oFFN_X oWrite_Data(oTextSave, oName_Parent) Next End Sub Function FindParent(Parent As Document) As String 'Find real parent Line1 : Dim oBOMStructnumber As String oBOMStructnumber = Parent.ComponentDefinition.BOMStructure If oBOMStructnumber = 51971 Then Dim parent2 As Document = Parent.ReferencingDocuments.Item(1) Parent=parent2 GoTo Line1 End If Dim ParentName As String = Parent.DisplayName Return ParentName End Function Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) End If End Sub End Class
Please check it, Regards!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
