Hi, here is an example I hope it is useful, it is a rule that after executing is automatically added to event, in the category of geometry change. For your rule in particular, replace the text box with your rule, or with the subroutine you have. Regards!!!
Sub main()
MessageBox.Show("Example", "Title")
Events
End Sub
Sub Events
On Error Resume Next
	Dim EventPropSet As Inventor.PropertySet
	EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
	EventPropSet.Add("Inicio", "PartBodyChanged ", 1200)
'After Open Document					: AfterDocOpen                 		: 400
'Close(Document)						: DocClose                     		: 500
'Before Save Document                   : BeforeDocSave           			: 700
'After Save Document               		: AfterDocSave               		: 800
'Any Model Parameter Change        		: AfterAnyParamChange   			: 1000
'Part Geometry Change**            		: PartBodyChanged         			: 1200
'Material Change**                  	: AfterMaterialChange     			: 1400
'Drawing View Change***               	: AfterDrawingViewsUpdate  			: 1500
'iProperty(Change)                  	: AfterAnyiPropertyChange           : 1600
'Feature Suppression Change**          	: AfterFeatureSuppressionChange   	: 2000
'Component Suppression Change*   		: AfterComponentSuppressionChange 	: 2200
'iPart / iAssembly Change Component* 	: AfterComponentReplace   			: 2400
'New Document                         	: AfterDocNew                  		: 2600
InventorVb.DocumentUpdate()
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
		iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
		If iLogicEventPropSet Is Nothing Then
			iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
		End If
		If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
			Call iLogicEventPropSet.Delete
			iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
		End If
		End If
			MsgBox ("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
			Err.Raise(1)
			Exit Function
		End If
	On Error GoTo 0
	Return iLogicEventPropSet
End Function
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
