insomnix
in reply to: insomnix
Finally found the solution to the problem. Have to find the view the sketch is on first, then iterate through all sketches on the view to find the ones to update by name. Delete the line and re-add the line for the section view.
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDoc.ActiveSheet
	' Get the view the section views are being created from
	Dim oView As DrawingView = ActiveSheet.View("FRONT VIEW").View
	' Set a reference to the transient geometry object.
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oSketch As DrawingSketch
	Dim line As SketchLine
	Dim vertLinePoint As Double = oView.Height / oView.Scale / 2 + 2
	Dim horzLinePoint As Double = oView.Width / oView.Scale / 2 + 2
	For Each oSketch In oView.Sketches
		Select Case oSketch.Name
			Case "vert"
				' Open the sketch for edit.
				oSketch.Edit
				' delete all lines in sketch
				For Each line In oSketch.SketchLines
					line.Delete
				Next
				' redraw line in the sketch to move section view
				Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, vertLinePoint), oTG.CreatePoint2d(0, -vertLinePoint))
				' Exit from editing the sketch.
				oSketch.ExitEdit
			Case "horz"
				oSketch.Edit
					line.Delete
				Next
				Call oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(horzLinePoint, 0), oTG.CreatePoint2d(-horzLinePoint, 0))
				oSketch.ExitEdit
		End Select
	Next
