216 Views, 0 Replies
03-04-2019
05:13 AM
- Mute
- Permalink
- Report
03-04-2019
05:13 AM
Modify Part Number help needed
I have a code from @Curtis_Waguespack , which creates unique new parts in my project folder from library parts folder. Each new created part gets a new "Part Number" (=filename). That is not always preferable. I am looking for a way to modify the original "Part Number" iproperty in the new created part.
In the library parts there is a custom iProperty called PTN_PARTNUMBER. I might be empty or it can have a text. If empty, do nothing, but if <> empty, I want to copy this value to the Part Number iproperty.
Could anyone help me to code this? Many Thanks!
Imports System.IO
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "U:\Johan\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
If oFilename.Contains(Six_Digit) Then
Dim oOptions As Inventor.NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
sFilename = oFilename
Exit For
End If
Next
If sFilename = "" Then
MessageBox.Show("No matching libary file found.", "iLogic")
Return
End If
iCounter = 0
'path from current file
oActiveAssemblyfolder = ThisDoc.Path & "\"
'path from current project file ( *.ipj)
oProjectfolder = _
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "\"
Dim oProject_Filenames() As String
oProject_Filenames = System.IO.Directory.GetFiles(oProjectfolder, _
'count existing project files
For Each oFilename As String In oProject_Filenames
iCounter = iCounter + 1
End If
Next
'increment counter
'find the postion of the last backslash in the path
FNamePos = InStrRev(sFilename, "\", - 1)
'get the file name with the file extension
oName = Right(sFilename, Len(sFilename) - FNamePos)
'get the file name (without extension)
ShortName = Left(oName, Len(oName) - 4)
'get extension
oExt = Right(oName, 4)
If iCounter < 10 Then
iCounter = "00" + CStr(iCounter)
ElseIf iCounter < 100 Then
iCounter = "0" + CStr(iCounter)
Else
iCounter = CStr(iCounter)
End If
oNewName = ShortName & "_" & iCounter
oPathandName = oActiveAssemblyfolder & oNewName & oExt
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add( _
oPathandName, oMatrix)
oOcc.Grounded = False
ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
