If you can manage without LOD's it would be more easy for your self. but if you would stay working with LOD's than you can change them with code..
when you save a part, than that will be in the master LOD.
maybe you can use the option "Link Level Of Detail", with this you can make all LOD's with the same name linked. that way if you choose one in the top assy, the rest will also be set to that one.
one thing to understand is that LOD's may not be used for making configurations!!
the strange thing is that iLogic is miss using LOD's... when you use component.isactive....
LOD's where introduced to make an assembly lighter, not make configurations!, so maybe this is what is causing you problems..
if your drawing views have a different LOD than you model, and you have them both open, you can't save...!
this is one of many things with LOD's, so that's why I don't use them any more..
why it does work in your other project I don't know. maybe less complex?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
