- Mute
- Permalink
- Report
Thanks for your replay Hans,
You told me that is better saving without LOD, in a Master mode, and then put a rule that control the differents LOD that are needed in my configuration?
But if I just need that all the time the level of detail were the same custom LOD, have I to do it too?
I have controlled the design views in the differents sub-assemblies and they are all in the correct form.
The problem is just when I save the drawing .idw, that change the LOD of the subassemblies of my model to a master LOD insted of the customisazed LOD.
I don´t know why this is happening. I have done a similar project before this one, and it runs perfectly...
The procedure I follow is this one:
1. I enter in the model and with a form and different ilogic rules, I change differents aspects of my assembly like the lengths or the activation of some parts/assemblies.
2. I save the model when it finished. Until here, there is no problems.
3. I open my drawing, where I have different sheets (between 25-28) with the differents drawings of the model, and I update it.
4. I export the different sheets of my .idw. Until here there isn't any problem.
5. Finally, I save this .idw
6. I reopen my model, and I can see how the LOD have been changed I don't know why, after saving the drawings. I have to enter in all the differents sub-assemblies and putting manually again the correct LOD. This take me several minutes (not so much, maybe 15-20), but its waste time for a thing that its supposed to run automatically. AND I can forget some of the subassemblies without change it, with a mistake that maybe I don't notice...
So, I don't know If I have done it one time correctly with other model, why with this one I have this error and how to fix it!
Thanks you again Hans!
